TPMS retrofit on rims
Old 07-02-2005, 09:44 AM
Mikla
Mikla's Avatar
Default TPMS retrofit on rims
There are many options to but used 20" rims for the Cayenne, but most of them do not have TPMS (RDK). Is it possible to retrofit the system to those rims? How much would it cost?
Old 07-02-2005, 05:39 PM
johnsamonas
johnsamonas's Avatar
Providing your car has RDK receiver,yes..you can retro fit RDK to any wheel.(I did on my 22"s),just order it through Porsche,,i think it was about £350 for 4 sensors.
Old 07-02-2005, 06:27 PM
Raptor
Raptor's Avatar
What is an RDK receiver?
Old 07-02-2005, 11:20 PM
johnsamonas
It is the unit that picks up and reads the radio signal transmitted from the sensors in the tire valves,and then sends it to the dashboard display...The car has to have been ordered with this from
the factory..I dont think this part can be retro fitted.
RDK...is the abbreviation for Tyre Pressure Monitor in German (roughly translated)
Old 07-03-2005, 12:58 PM
Mikla
Mikla's Avatar
Thanks. Is it necessary to bring the car to the Porsche dealer to install them or it could be done in any tire specialist?
Old 07-03-2005, 01:30 PM
Cay-ute
Cay-ute's Avatar
Mikla, you can add the TPMS sensors to any Porsche wheel. I have them on my Cayenne and on three different sets of tires. Make sure that your vehicle has the TPMS system. It takes about ten - fifteen minutes for the system to detect the sensors. Good Luck!!
Old 07-03-2005, 03:07 PM
johnsamonas
any tire specialist can fit them for you..but if you dont buy them from porsche,make sure they are the same frequency as your receiver.
please note....if you are transporting other wheels in your cayenne which also have the sensors on them,the TPMS will not work,as it will try to get readings from ALL the sensors,and get confused!!!
Mine actually gave me this warning : TOO MANY SENSORS !! , when driving back from the tyre specialist with my 19"s in the back...
Old 07-04-2005, 10:33 AM
Mikla
Mikla's Avatar
I've just spoken with the Porsche dealer and they didn't know if the sensors could be retrofitted or not (!). How are the sensors attached to the rims?. Are they glued?.
If I buy the rims I would bring them to an independent shop. This is why I'm asking.
Thanks in advance
Old 07-04-2005, 11:21 AM
johnsamonas
they are stuck on with some sort of industrial strength adhesive.....
your car has RDK option on it , right ??
Old 07-04-2005, 11:29 AM
Cay-ute
Cay-ute's Avatar
Mikla, the transmitters that go onto the rims are screwed on, no adhesive is used. I am not sure how the sensors are attached to the vehicle as I have never seen the ones on my car. Adding the transmitters to the rims can be done by your independent tire shop. Not sure what to do if your Cayenne does not already have the TPMS sensors.
Old 07-04-2005, 05:11 PM
Mikla
Mikla's Avatar
Thanks guys,
My Cayenne has the TPMS. I have 18" Turbo rims and this is no issue. But it seems that here in Spain there's no knowledge on this: I've been told that they don't know if it is possible to retrofit. Thanks to you guys for letting me know it is possible.
Cay-ute, if the transmitters are screwed on, do I need to screw the rims?. Is there any specific way to do this?
Regards
Old 07-04-2005, 05:26 PM
alex911s
Man of Many Porsches
alex911s's Avatar
here someone posted this before, just order the parts and show this to your tire place. Hope this helps, it looks like he retrofitted it on the OZ canyon wheels.
http://www.leonoff.net/pages/cayenne/tpms/tpms.html
Old 07-04-2005, 09:22 PM
pdxjim
pdxjim's Avatar
I got mine from Tirerack.com and had an independent car shop put them on my snow tires. Any mechanical/tire shop should be able to do it. I did notice when I was driving home with the summer tires in the back, the monitor was acting up due, to I think, 8 sets of transmitters in the truck!
Old 07-05-2005, 07:31 AM
johnsamonas
mikla,...sorry for some confusing/conflicting posts..here is the truth straight from my Tire Specialist:
quote:
Dear John
The sensors fix to the rear of the Porsche air valve. This is done with one
single, small threaded bolt into the tyre valve. They are easy to remove but
as the original bolt is pre-treated with a thread-locking compound the
person fitting them should apply some fresh locking compound to the threads
before putting the bolts back in.
Regards
Unquote
So it is basically threaded into the valve,with adhesive to hold it in place.See also the following link,(under Transponder)
http://www.iqmobil.com/index.php?m=R...GY&language=en
Old 07-05-2005, 09:55 AM
Mikla
Mikla's Avatar
Dear John,
Thanks so much for your help. I now have all the ideas quite clear and I'll go and buy my second rim set, that I plan to use for summer only. This set has the Pirelli tyres, any feedback on them?
Regards
Quick Reply: TPMS retrofit on rims
