Airbag Fault Light
Any ideas for how to reset this light? I tried my old favorite of turning the key to the left and holding it there for 1 minute to reset the computer. That didn't work.. Just trying to avoid a drive to the shop so I'm open to suggestions.
Steve
2004 CTT
Steve
2004 CTT
Better take it into the shop. There's a known wiring issue that causes the fault light to go on even though the air bag is OK. The dealer has a TSB for fixing the problem so it doesn't come back. Mine was done back in April.
analyst
The airbag fault requires the PST2 / PST3 to reset. There is a fix to resolve the problem which will prevent future failures. The airbag that the vehicle determined is faulty will remain inoperative until the fault is cleared.
"Dirver front side airbag wiring update needed. Checked faults - see print out for fault #1217, inspected and side airbag connector replacement had not yet been done. Performed update on both front seat side airbag wire harnesses. Cut, crimped and soldered wire harness, R&I both front seats for access."
analyst
Originally Posted by PTEC
Thats not necessarily true, unless there is a open continously present short or open circuit. In the majority of cases, the airbag will still deploy even if the light is on (aka the majority of Cayenne airbag light issues.)
Not according to the factory service manual which states that the airbag with the fault is disabled.
Repair complete.... Required removing the underside of the seat to get to the airbag cable, and removing the quick release connectors and soldering it all together.
Steve
Steve
analyst
Where would that be, I would like to read that for myself. I've got "Cayenne-6901 Airbag Introduction" in front of me and I dont see anywhere explicitly that the presence of the airbag will disable that airbag.
analyst
The manual also states that intermittant faults are automatically cleared after a specific number of ignition cycles, 30 or 50. But, airbag faults remain until manually cleared by the dealership.
So, a detected airbag fault will remain active even if the cause for the fault has abated. The affected airbag will be prevented from triggering until the dealership clears the fault.
The manuals have that information too.
