Wench mount/kit for the Cayenne?
Old 04-10-2005, 11:20 PM
bojali
bojali's Avatar
Default Wench mount/kit for the Cayenne?
ok after getting stuck in the mud and needing about 20ft of cable to pull my Fat CS out, and getting $$ by a tow jocky. Does anyone make a wench kit for the cayenned?
i figure about a 10K lb Warn Wench with a nice modified Stainless steel front pan. anyone?
Old 04-10-2005, 11:41 PM
GM Austin
GM Austin's Avatar
If you have a hitch you could buy one of the Warn models that attach to the receiver. You might also look into the VW Touareg parts bin. There is now an optional winch from VW for the Touareg.
Old 04-11-2005, 12:15 AM
bojali
bojali's Avatar
na, I have researched that! I see that Warn has a kit for the H2!! which is about the same age as the Cayenne.. and I dont want to be hauling a portable unit around, with the limited rear storage area.. ok I can hang it off the back as I go.but come on, this is suppose to be a "off road" SUV...
anyone want to design an unit? I have used the Hidden Warn units in my Tahoes, a design similar to this would work, Plus would be a unit that works with the front pan. ??
Old 04-11-2005, 01:14 AM
jhunt@huntinter
jhunt@huntinter's Avatar
hmmm... wonder if I can get a wench kit for my Rover :-O
Old 04-11-2005, 09:17 AM
GM Austin
GM Austin's Avatar
I have heard that wenches love rovers, so, yeah, go for it! I am planning on a wench kit for my Cayenne too. It involves folding down the back seats, installing some darker rear window tint and adding an air-up mattress.
No, seriously, I think we're really talking about winches here. Again, check out the VW Touareg parts bin. They already have a Warn winch installation on their Expedition model of the Touareg. See below. Check out this news article from GermanCarFans: click here
Old 04-11-2005, 02:29 PM
bojali
bojali's Avatar
Thanks, Forgot about them.. and yes its winch.. i have the other version.. ;^)
Old 04-11-2005, 03:22 PM
bojali
bojali's Avatar
called the local VW dealers, nothing on the winch system, that they have knowledge of. now calling Warn to see what they might have....No clue. :^( Off to the local 4wheel drive shop I go
Old 04-11-2005, 04:35 PM
GM Austin
GM Austin's Avatar
No surprise there. Dealers never seem to know anything.
Still, I would like to see someone look into the VW winch solution. VW will have all the necessary mounting brackets and hardware and they will have tested everything. I think it would be better than an aftermarket solution. It's just a matter of finding the right VW part numbers. Maybe one of the online VW parts houses could be of help.
Old 04-11-2005, 07:30 PM
mudman2
Moderator !x4
mudman2's Avatar
I thought they came standard John, with handcuffs even !
Old 04-11-2005, 07:55 PM
GM Austin
GM Austin's Avatar
And, just so we don't get TOO far off topic, let's not even discuss mounting the wench!
Old 04-11-2005, 08:47 PM
jhunt@huntinter
With the right setup I hear you can mount a wench on the front or back .
Old 04-11-2005, 08:50 PM
mudman2
Moderator !x4
mudman2's Avatar
I had heard that but never managed it even though the grab handles are very well placed.
Old 04-12-2005, 02:42 PM
bojali
bojali's Avatar
Winch: local 4 wheel shops wont touch it due to a liability issues. so checking with my P-dealer and his contacts at the other VW shops, no clue (as expected!) on the kit used in the Touareg. No news on the dealer side either....
so off to the garage to remove the lower skid plate and start measureing..
Old 04-12-2005, 02:47 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Post
Perhaps VAG is not offering this option/equipment in the US?
You may ask Gert (www.carnewal.com) if he has any information from the other side of the pond.
Old 04-12-2005, 04:45 PM
bojali
bojali's Avatar
thanks will do!
Quick Reply: Wench mount/kit for the Cayenne?
