Overhead Console Switched Power?
Hello Guys,
I was doing a Homelink retrofit and a V1 Hardwire install. Does anyone know where I can get switched power in the overhead console area? I have found plenty of always on power...but cannot seem to locate a switched power.
Any help would be great.
Thanks,
Parag
Thanks,
Parag
Supplier for what?
I made the Homelink myself...
And the V1....not sure what who to ask.
I have metered every wire up there...I found one that seemed to be good...but it must be light related...
Thanks,
Parag
Thanks,
Parag
Just to sum it up.
I couldn't find any power in the overhead console.
So I ran a wire down to the driver's side fuse box. I removed the A Pillar cover to ensure proper wiring so it did not interfere with the airbags.
All is done now! My Homelink works perfect, and my V1 is hardwired.
Thanks,
Parag
Thanks,
Parag
It's not fun...
I'm very used to BMW...so I'm not "scared" to break things...
But...pry out the little ABS plastic logo...
Then remove the star screw...
Then yank on the whole pillar towards the opposite A pillar....after you hear 2 pops...for the 2 plastic rivets.....carefully pull out the piece.
It is NOT fun to put it back in....just reverse the directions...
Good Luck,
Parag
Good Luck,
Parag
