Beach Driving in a Cayenne... Yeah or Nay?
The Cayenne is spending the week on the outer banks, and it seems that exploring the island by 4x4 is all the rage. I know from a technical stand point that the C is capable, but I am very reluctant. Does anyone have some experience that they are willing to share, tips and tricks as well as must haves?
Also if anyone is in the area and is looking for some thing to do misery deserves company....
Some tips:
Avoid softer areas or large dunes until you've got some experience. You may also want to lower your tire pressure to 25 PSI or so. This will increse the surface area of your tire. Also, you may want to use a more "offroad" type tire depending on what type of tire you have now. A pure "summer" tire is going to have less traction on sand or mud than a "all seaon" or "offroad" tire. One simple indication is to check for the "M+S" rating on the sidewall. That means "Mud and Snow" rated. It's not a really good rating, but you'll be better off than with a summer only tire.
I have a set that I use for winter and offroad driving (M+S rated) and a different set for normal highway driving (summer tire).
Alex
Alex
Definately take it to the beach. I live in san luis obispo, which is minutes from pismo beach, the only legally driveable beach in california. The dunes are awesome. I've seen a few cayenne's out there just tearing it up, and these dunes are massive. The cayenne just climbs straight up them and its incredibly steep. The air suspension and the ground clearance that comes with it makes it unbelieveably capable, although steel suspension would do just as well. Definately lower your air pressure to less than 30 psi, and even lower if you happen to get stuck. Its a blast and if you bought an SUV and are reluctant to take it off road (especially one as capable as the cayenne), then trade it in for a sedan :P
Hundreds of engineers spent years ensuring this car could rough it off road - do them justice!!!
in 73 in the houston/galveston area were everybody drove on the beach, i had a $ 700 skylark, not too old, but i kept having to fix wire connections and similar stuff.
a mechanic told me that it had probably been driven on the beach (and in saltwater?).
anyway, knowing what sea air and saltwater do to things, would you be worried?
k. a.
k. a.
analyst
Don't be afraid to put it onto jack stands and take the wheels off following the fun, for intensive cleaning. Sand will get everywhere and it is both corrosive and abrasive, so a good cleaning is the way to go.
a good cleaning is good advice, just make sure to do it with LOW PRESSURE! it always kills me to see people take their car to a high pressure car wash or use a pressure washer (or even blast away with a hose with a nozzle going full steam) to get salt and grime off. all you're doing is driving the crap into the little nooks and crannies on the car where it will do the most damage, and be the hardest to remove! do yourself a favor and use low pressure with high volumes of water to remove the salt and sand.
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
