Oil filter housing
In the middle of an oil change and I can't seem to get the housing off. Its super tight. I know my lack of appropriate tools is not helping, ordered a socket that was too long to fit in the space with a wrench and my adjustable wrench is very short. However, I have ordered a 36mm combination spanner so that should help. I have sprayed some WD40 on some edges that I could see/reach around the housing, any other tips?
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1024x768/img_3196_d82eb1ff93d940af52b9e6093b6f4d4233d4a42f.jpg)
The oil is out though, so I'm half way there haha
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1024x768/img_3217_9de86a6b9487c49ff95caad044f82d7c59e2e7e1.jpg)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1024x768/img_3218_97e6e79fe7a716d025a0fc6e8733b17218553c68.jpg)
The oil sump plug is proper soft, so I would recommend buying a new one each time. Oil is a little darker than I would like but I will try and reduce the oil change intervals during my ownership.
Is this a 3.2L VR6? My 2009 and 2016 3.6 both have drains in the filter housing. They are tight, even when I properly torque them but always break free with a 36mm socket, extensions and decent length ratchet. I snagged an Icon 3/8" breaker bar on close out at HF and it is the perfect tool for freeing these. Look for a 36mm oil filter housing socket on Amazon, it's like $6 and a lot lower profile and lighter than a typical 36mm. Much less awkward to use. I would upgrade the housing to one with a drain as it will be a mess without it. Once I loosen it a bit I put a big ziplock bag and try to catch the overflow oil. Ol changes on this engine is the only thing I don't like about my Cayennes and on a 958 it's even worse.
Mark
Mark
Mark
Mark
Yeah it hasn't been as smooth sailing as I was hoping but hopefully with the spanner it won't be too much longer before this job is sorted.
theworkerbee (07-30-2024)
