What is this awful whine?
My 04 CTT has this nasty whine which increases relative to engine speed.
At higher RPM's you can't even hear the V8 over the high-pitched whining sound, it's that bad.
The whine has existed for a fair while but I feel like it worsened after my mechanic did a transmission fluid and filter change a long time ago.
Since then, it has had one more filter replacement and numerous transmission fluid changes to try and fix the issue, but the whine remains.
The three most likely causes I can think of are
The car has about 206,000 miles on it now so it is getting up there, but I think it drives too well for this to be a more serious internal transmission problem.
Any thoughts and advice appreciated.
- Cavitation in transmission due to under/over filling
- Cavitation in transmission due to poorly seated/damaged filter o-ring
- Noise from bad accessory or pulley on the serpentine belt
Hard to narrow down as I hear a few separate noises going on there. Does the noise change while turning or driving straight? Can you hear it while coasting in gear or in neutral? If it's truly in the transmission...with 206k miles, turn the radio up.
tassieporsche (07-12-2024)
Definitely not a wheel bearing, it's not that sort of noise.
Took the car for a bit of a spirited drive and interestingly it seems to have calmed down a bit, although still present.
Going to get it up on a hoist soon and run it it to try and pinpoint the source. I'll do a trans filter change at the same time as I've seen so many cases of this where people haven't installed the filter o-ring correctly causing cavitation and thus a whine. Good chance to ensure the fluid level is accurate too.
It's directly linked to engine RPM so it's either something in the drivetrain or a belt driven accessory, but I believe the former is more likely.
Yeah the mileage is high but I think there's a decent chance it might be something that can be corrected. I've just seen a lot of cases of this, especially with these gearboxes and their silly and difficult fill procedure. A lot of people on these forums seem to suggest the Porsche procedure is wrong and you need to use other methods to truly acheive the correct level.
Quickly eliminate belt driven accessories by momentarily releasing the serpentine belt.
No harm done running it like this for a few min.
BobcatBrian (07-13-2024)
Doesn't change during turning vs straight driving, and it can't be heard while coasting.
You'll get more feedback by uploading the video to youtube and placing the link here. Many of us won't download a random file from a forum.
