Tailpipe pointing downward
Old 06-07-2024 | 05:12 PM
OvalPiston's Avatar
OvalPiston
Default Tailpipe pointing downward
I backed into something and now my passenger-side tailpipe won't stay "up". I can push on the driver-side tailpipe and it stays put.
Is there a hanger or tabs or something that holds the tailpipe up? Maybe it broke off?
Old 06-08-2024 | 08:50 AM
Petza914's Avatar
Petza914
Loosen the clamp, rotate the tip to where you want it and make sure it's all the way on the muffler joint, then tighten the clamp.
Old 06-08-2024 | 08:58 AM
OvalPiston's Avatar
OvalPiston
Do you mean there is nothing holding the tailpipe on except friction from the clamp? I thought there might be some tab or "pin" that guided the tip on?
Old 06-08-2024 | 12:18 PM
thesteve's Avatar
thesteve
That clamp has a crack in it.
The same thing happened to me on my left side and I don't think we backed into anything.
I can see a crack beginning on my right side too. I bought two clamps but haven't done the job yet (mine is only sagging slightly and is locked completely).
I'll look for the part number.
95511110822
Old 06-08-2024 | 02:13 PM
Petza914's Avatar
Petza914
Correct. As another poster noted, you need new clamps.
Old 06-26-2024 | 09:16 PM
OvalPiston's Avatar
OvalPiston
Guess those clamps are very strong to hold that much mass! New clamps worked. I replaced both sides. Thanks for everyone's help.
Quick Reply: Tailpipe pointing downward
