Pressure valve questions
And conversely if the front valves were bad, would it not air up??
Is it possible to simply use and air compressor and try and put air into each corner line and see if one front corner raises?
im going to pull the air valves in rear and see what that does.
So i was going over the readings again. I see that my system/tank pressure seems to be about 3580mb, which equates to 52psi,(and the air bags at 5580mb (80psi)) But if the rear rises then, thats enough to work No??
and (I couldn't find 100% accurate info) but it says system pressure should be about 10bar which is 145psi (but I have seen a couple mentions of system working at 8 bar (120psi)
can anyone tell me if that would give me THIS error? and can anyone point me to actual pressure readings so i have something to compare to? I couldnt find an actual chart with pressures.
one thing that seems interesting is that when I try to put it in Loading position, it always says "pressure accumulator filling"
so with no errors where else do I look?
Try mechanically disconnecting the ride height sensors at the front, then hook up your scan tool and move the sensor’s arm. See if the value for ride height changes on the scan tool as you manipulate the sensor.
While I can’t say for sure, I don’t think you have a pump problem. You mentioned, the accumulator pressure. There are two accumulators, One for the front and one for the rear. One accumulator is on the left side of the spare tire in the trunk. The other accumulator is underneath the car on the left side approximately underneath the left rear passenger’s feet.
Based on everything you’ve been working on it seems like the front half of the system isn’t getting air pressure and that the electrical system is working. If I had to guess, that means either a leak on the front half of the system. Or the sensors are giving a false reading that won’t trigger the valve block to fill the front. And I think you said you replaced the valve block?
Last night I put in a new level sensor on the Front Right (this one had the lowest reading/measurement, so I figured id try that first)..... But again no difference. it shows pretty much the same reading as the old sensor) Both sensors show the front is down, and looks to be reading relatively correctly (though one side shows about 10mm lower than the other)
I didnt know about the front, from the looks of the diagram its under the drivers seat. and is slightly bigger. I used soapy water at the pump, didn't find any leaks. are there any valves near the front accumulator?
I will say I did get an Initial error when I first start the car, and that is the "below lower limit" but once that is cleared and it runs for a couple minutes, I dont get any more errors. (except for a time out on the pump running) but since the lines were all disconnected previously, that seems reasonable.
Have you leak checked the front half of the system? Check for leaks from rear accumulator #6 all the way around to the pump #3. Not only would I check for leaks, but also the presence of air on the front half of the system. (You won’t have a leak if there is no air pressure).
I know this has been frustrating. Keep at it, at this point it is a point of pride!
No. Description of component Number Location
-1- Air spring strut, front axle 2 Wheel housing/lower control arm
-2- Air-spring strut, rear axle 2 Damper housing (cross
member)/wheel bearing housing
-3- Compressor 1 Underbody right
-4- Valve block 1 Underbody right
-5- Front accumulator, 5.21 litres 1 Underbody left
-6- Rear accumulator 4.87 litres 1 Boot floor plate
-7- Air suspension control unit 1 Luggage compartment right
CALIBRATION
Calibration must be carried out if control unit and/or self-levelling sensors are replaced. When doing this, the
self-levelling sensors are calibrated by determining a correction value (corresponding to the actual height of
vehicle) and permanently storing it in the control unit.
Notes on calibration
The nominal values for the nominal heights of the level sensors are stored in the control unit. The actual values
of the respective axle heights, front left, front right, rear left, rear right, have to be measured manually and then
entered with the Porsche System Tester. The actual values are to be measured on the two axle supports (front
axle, rear axle), both on the right and left. --> Conditions for carrying out calibration.
Measuring point for rear axle
-8- Body acceleration sensors ( 2x front
and 1x rear)
3 Front wheel housing (right/left),
boot floor plate right
-9- Wheel acceleration sensors 2 Spring strut front
-10- Self-levelling sensors, front axle 2 Control arm upper
-11- Self-levelling sensors, rear axle 2 Control arm upper
-12- Compressed air connection 1 Under seat frame front right
-13- Suction line for compressor 1 Connection to air cleaner housing
CALIBRATION
and 1x rear)
sure how can I get that?
its getting to be a pain to have the car running to check the system and test everything.
I see very little info about leaks in other places other than the pump and struts.
Unfortunately that diagram doesn’t have the detail you need to understand the flow of the system. From a simple system design perspective, the pump and accumulators must sit on one side of the valve block, and the struts on the other side of the valve block. Looking at that diagram, I can tell that there is more than one line running between components, and those extra lines aren’t shown on the diagram.
Pump fills accumulators, valve block dispenses air to the struts.
Feel free to PM if you need.
