What’s this thingy under the dash?
I’m trying to find a good hot and a switched power source under the dash and came across this plug just hanging out, any idea what that’s for? Maybe entry and drive (an option I do not have?)
What’s that plug?
While we are at it, any suggestions for a good site to tap in that big bundle? I’m trying to avoid fuse taps, just because. Thanks!
and no I can’t use the mirror. Gotta be under the dash for this install.
What’s that plug?
Any switched circuit you find will be fine for that. Looks like that plug has both power and ground so you'll be all set. There will be a connector number on it where you can look up it's mate in a pigtail format so you can connect your stuff to the pigtail and just plug them together for a nice clean install if that's the trailer connection, can probably just look up the trailer pigtail and buy one of those.
The following 2 users liked this post by TomF:
BobcatBrian (12-14-2023),
Flemming50 (01-31-2024)
Mine was getting tired, so I ordered a new one from Oreilly's. https://www.oreillyauto.com/flux-capacitor
Crozzer (12-14-2023)
Now if I found an unused plug with one switched and one constant circuit, we'd be in business.
As it is, I think I'm going to do surgery on the bundle of wires just to hide the taps under the dash, then run to a new small fuse box that is functional and accessible next to the rest of the fuses.
Close enough to looks nice (without the pain of figuring out how to add new circuits to empty slots on the existing fuse board.
You order the trailer brake wiring harness from the dealer that has the correct connector for the plug. Then you buy a trailer brake controller of which there are many brands (I bought from RedArc) and it will wire up to the harness.
This is only required if you have a trailer with electric brakes. Many trailers have surge brakes which don’t need any of this. Figure out what type of trailer you have, and that will tell you whether you need to wire up a controller.
May I ask what you are wiring up? If it is a dash cam then a good solution is an adapter that uses the OBD port. It will sense the voltage and stay on until the voltage is too low and shuts off (cannot remember what the actual voltage point is). Works well for me.
