12V socket under glovebox
Old 12-18-2023 | 09:03 AM
Mounts's Avatar
Mounts
2nd Gear
Default tv mounting service
Originally Posted by theworkerbee
Hey guys,
First post so sorry if this has been asked before but I haven't been able to find it.
So unplugging my dashcam every time I turn the car off is getting annoying. I had a look under and my car only has the one 12V socket so I bought a used one and thought I'd wire this one in so that its ignition live. Once I received it I noticed there are 3 pins, I was expecting 2, a ground and a live. Does anyone know the wiring schematics and what the 3 wires are for?
I recommend a company that will install a TV on the wall.
The below is a screenshot from a video that shows you the wires:
Have you found the scheme?
Old 12-18-2023 | 11:27 AM
theworkerbee's Avatar
theworkerbee
I'm not sure what you mean, but the third wire did indeed seem like it was for a light
Old 12-18-2023 | 12:06 PM
theworkerbee
Remove centre torx screw:
Then gently pull the cover down, only a couple of clips holding it in place. I took reference from the socket that is already there so I knew which pin to use:
Then remove the fuse cover:
Below is the empty fuse slot that I used as well as where I grounded the socket (circled in red):
It took a while to find a suitable ground location, once that was done it was easy.
Quick Reply: 12V socket under glovebox
