200k miles. What a vehicle!
Finn, my '05 VR6 Cayenne, just crossed 200k (202k today, in fact), and he's still going strong.
I bought Finn in 2010 with 82k for $16k, and in the last 13 years and 120k miles, he's only left me stranded once (fuel pumps!). (Unless you count the time he sunk to the floorboards in a muddy field and had to be pulled out by a tractor.)
But he's also done everything I asked and more. I can't count the amount of stuff I've loaded into him, onto him, or dragged behind him.
Finn's needed his share of maintenance, of course. I can't fault that. Three cardan shafts (and two Jimmi Fixes), flex pipes, three sets of brakes, coils, a repaired headliner, a replacement door, replacement headlights, a spot of rust or two, some missing trim, two sets of hatch struts, fuel pumps, two cabin blower motors, transfer case actuator motor, secondary air pump, fuel valve, O2 sensors, and so on. All typical and most of it done by me in my garage with hand tools.
I was originally thinking that I'd only take him to 200k and then move on to something else. But he's still running so well that I can't justify it. And without all the fancy stuff that you get on the higher end Cayennes, I can't imagine what could go wrong that will force me to junk him rather than fix him. Even if the engine quits, I can see several entire VR6 Cayennes on FB marketplace an hour or two from me with half the miles for $3k or less.
What a great, great vehicle! Porsche hit it out of the park with the Cayenne!
The following 8 users liked this post by Shawn Stanford:
BrianC72gt (12-08-2023),
oldskewel (12-08-2023),
rosskuhns (12-11-2023),
Spyder_2011 (12-08-2023),
SuperG$ (12-08-2023),
and 3 others liked this post.
I love hearing this! Long list of maintenance but in reality at that mileage you’re still way ahead and the driving experience is excellent. We recently acquired a 2010 with just shy of 100k miles and have since put about 6k miles on it with zero issues. The driveshaft bearing was replaced at 80k miles so we should be good for a while.
You noted that you replaced three of the driveshaft bearings in your span of ownership, were the replacements the upgraded part in all three instances? I’m curious what to expect as far as longevity of these bearings.
Oh and at minimum you need to post up some pictures celebrating the 200k mark!
Great post Shawn.
I did a 1 piece aluminum driveshaft in my Turbo S - no bearing and no bearing support to deal with.
I use mine differently than Shawn, but love it just the same
I expect 50k miles or so from a set of bearings. The Jimmi Fix turns it from a $500 2-hour job into a $15 30 minute job.
Spyder_2011 (12-10-2023)
Nice! Always enjoy stories of people using and enjoying their Cayenne's and them being solid. Enjoy!
No, from www.driveshaftshop.com
I remember they never showed one for the 957, just the 955, but it worked fine on the 957.
There are other odds and ends repairs I made over the years because things just wore out, and right now I have a CEL I need to track down, the trip OD reset isn't working, the fuel gauge isn't accurate (I think because I bent the float when I replaced the pumps years ago), and the rear seat belts are locked and need cleaned/lubed or replaced.
I wish 928 dashboards held up so well.
tomhartzell (12-11-2023)
