Tire pressure for long storage
I'm going to store my CS for a while (over a month), The dealer suggested that I inflate all 4 tires (50 to 60 psi) not to develop flat spots or whatever its called
I have Michelin Diamaris 20" rims , and on the tires it says (Never inflate over 40 for flat beads) I have no clue what that is?
So what do you suggest? could it be that the dealer gave me that advice based on if I have the standard tires but not the 20" rims?
So should I inflate the tires or not?
Thanks a lot guys,
Thanks a lot guys,
analyst
It would not hurt to lift the vehicle and rest it on jack stands, as shown in this post: https://rennlist.com/forums/showthre...hreadid=109174
While we are talking about tires, anyone reccomend the best "winter" tire for the "DC" area that will fit on the set of 18" rims I purchased for my winter shoes?
I have Cont's 4x4 MS tires on them currently... My Cayenne came with P-Zero's on the 19" rims.
Any help or "links" if anyone can remember if this thread was covered in detail is appreciated in advance.
Originally posted by docjackson1
i see nothing wrong with the conti m+s tires that you have-with the awd and psm, you should be able to get thru almost anything.
Mazximum tire pressures are set with variable loading in mind (potholes, dips). Since storage would be a static load - 50lb should be OK (You would get less of a flat spot than with 40.
Hello guys,
Thanks a lot for your inputs. I inflated all 4 tires to 50 psi, however, the car looked higher from the front, and it actually looked a little weird!
I just wanted to ask, what does a flat spot mean? My guessing that some spots in the tire would be out of air. But wouldn't the air inside the tire even itself once I drive again?
Guys I'm clueless about tires, please help me to learn something new
