Dipped beam error - ballast
Old 06-25-2024 | 07:04 PM
ChlkBoardJanitor's Avatar
ChlkBoardJanitor
6th Gear
Originally Posted by Ryanschoolya
The short answer is, I've found out, buy new headlights.
Really? Even after you've tried programming similar/ matched ballasts?
Old 06-25-2024 | 07:13 PM
Ryanschoolya's Avatar
Ryanschoolya
It's impossible waters to navigate due to all the Chinese knock offs.
Old 06-25-2024 | 09:25 PM
PourBoi-Jay's Avatar
PourBoi-Jay
You’re still in the wrong forum for a 958.2.
Post your questions here:
https://rennlist.com/forums/cayenne-958-2011-2018-242/
Someone with a PIWIS-3 might be able to help you locally
Old 06-26-2024 | 04:56 PM
slavie's Avatar
slavie
@slavie I have a 958.2 that needs a similar process. Any chance you'd be willing to help out a newbie 'lister? I'm in NY. Thanks in advance!
958.1 ballasts are same size as 957 ballasts but are definitely programmed differently. Not interchangeable at all. Installing 958.1 ballast on a 957 causes the CAN network to go down, so wipers, radio, headlights malfunction.
958.2 ballasts are different. I haven't tried programming either 958.1 or .2 ballasts.
957 ballasts are no issue, even the several Chinese knockoffs I've come across.
Not sure if buying new headlights will help you with programming, as I don't know if 958.2 requires programming. I could maybe give it a try, but I'm out of town this week. If you're not in a hurry, maybe.
Quick Reply: Dipped beam error - ballast
