Got a trailer, I have lighting issues...
Old 05-11-2004 | 10:57 PM
Periokid's Avatar
Periokid
Default Got a trailer, I have lighting issues...
I had a porsche hitch installed on my C T and I picked up my trailer today.
My brother in law walked around the trailer to check the lights since i was getting a trailer light out warning on my instrument cluster.
Tomy dismay, the lighting is not working properly.
No brake lights, no left turn signal. I do have front orange markers, and right rear parking light and turn signal.
Could the Cayenne be wired wrong?
Does the 7 pin connector only go in one way?
Old 05-11-2004 | 11:21 PM
wingless's Avatar
wingless
analyst
Yes, the 7-pin connector only goes in one way.
Frequently the problem is with the ground. That problem is often coumpounded by rust.
Each lamp MUST have a solid ground. The trailer MUST have a solid ground connection from the 7-pin cable.
To get solid ground, the metal must be clean and rust-free at the connection. The wire must not be green with oxidation.
The best bet for green wire is to replace it with marine-grade pre-tinned wire, available from any marine store.
It is possible to test both the vehicle, with a voltmeter and the trailer, with a +12VDC power supply or battery. This has the pinout: http://www.pollakaftermarket.com/images/1094-WC.jpg
Old 05-12-2004 | 08:59 AM
mudman2's Avatar
mudman2
Moderator !x4
Mine has working and turn signals and brake lights but no side markers.
The dealer fault found it to the control unit.
I get the same warning on start.
Back to the dealer.
Old 05-12-2004 | 10:33 AM
Periokid's Avatar
Periokid
Default Re: Got a trailer, I have lighting issues...
To my dismay, the lighting is not working properly.
Old 05-12-2004 | 09:55 PM
38D's Avatar
38D
I had a similar issue with my trailer. Turned out to be a blown bulb on the trailer (one of the brake/turn signal bulbs). Once I replaced the bulb, everything worked fine.
Old 05-13-2004 | 06:10 PM
wingless's Avatar
wingless
analyst
Quick Reply: Got a trailer, I have lighting issues...
