2008 V6 coolant leak, cant find the part on realoem! 🤬
Finally found my elusive small coolant leak. Found a buncha crusty coolant on the right side of the block near the back, about 4inches or so.
It APPEARS to be a heater hose but i cannot tell. It has a flange that mounts directly into the block, im guessing its the o-ring leaking. It leaves the block and makes a u-turn into a heatsheild headed behind the block. I lose sight of it after its in that flexi heatsheild.
I cant find it in the parts catalog. Im not losing much coolant, but i wanna take care of it before its a bigger issue.
https://www.renntech.org/topic/51734...ant-leak-help/
This is probably it. Happened on my 2009 as well.
Looks like it! Thanks!
