Cayenne Propshaft vibration help
Hi All,
I had a nasty thumping vibration coming from the prop shaft and was told it was my centre support (donut), so I ordered the EPS Carson shaft support kit from Design 911 and fitted by my local Porsche guy (Indy)
picking the car up it’s worse than before with now a mechanical grinding noise and the vibrations seem to be tied to the car and it shakes at 40-50mpg which it didn’t before
He says it will need a new prop shaft.
so I’m trying to research whats the best way to go refurb or aftermarket. But while looking on forums I’ve seen some people who have had problems where the prop was removed but reattached unbalanced? With similar symptoms.
anyone got any advice
cheers
cheers
That pic is indeed the EPS (European Parts Solution) as shown on the link. I installed that on my 2004 S and it was a great solution. When I did it, I was very cautious about assembly, alignment, etc., and for that reason did not even touch the Giubo. I did notice when down there that the transmission mount had collapsed partially, so I shimmed it up with some rubber hose, getting things back closer to their nominal alignment and orientation.
I agree with the others that most likely the problem is sloppy assembly, and that it just needs to be re-aligned and adjusted more carefully. You will find lots of stories on here where people had vibration issues following this repair, and I think they are all from the same cause.
Mongler04 (09-13-2022)
Don't waste your money on the EPS kit. Get a new GKN driveshaft and save yourself the trouble. See my post below, where I show a failed intermediate support BEARING that the EPS kit will do nothing to fix:
https://rennlist.com/forums/cayenne-...l#post17791767
LOL whatever, these kits are the best... your bearing failed because it was bad BEFORE the EPS kit was installed. that is very common for someone to install this either incorrectly and toast the bearing or its too far gone. \
No one should listen to your comment... you do NOT need a new shaft.... infact you can drive off the old bearing, and install a new one for $10. the Kit is to fix a failing support rubber mount... not fix a shot bearing.
ALSO your video is BS... clearly the OLD rubber is still installed and thus the kit.. if installed would have never worked. this video is clearly of a bearing that is shot and no kit ever installed so i have no idea what your even trying to get at with it. You have no supporting evidence or information of your story.
If you have no idea how to change out a bearing... but you went all the way to replace a $500 shaft... total fail.
what about it did not work? Im 100% sure that the kit WORKED.. you just had a damaged.. improperly install... or already bad bearing. nothing to fault with the kit. the kit is a near life time repair compared to nearly anything else on the market for the $ including a new shaft.
as i stated... you can easily swap out the bearing for $10 and a few normal tools with the EPS kit. Bottom line that these get a bad review from is from pure ignorance or lack of ability to install as it is a DIY item. unless the shaft was damaged then it will remain balanced.
Throwing parts at the problem with out understanding how to not spend a grand! also these shafts CAN be balanced at nearly any shop that does shaft work. lol
Also, since you clearly have no idea what you're talking about, that thing you call a "$10 and a few normal tools" entails taking apart the driveshaft CV joint and a press to replace the bearing, among other specialty tools. I'm sure everybody here has got that in their "normal tools" category.
The product works for many. Seems like a good kit. But it didn't work for me.
The solid aluminum drive shaft did. Perfectly balanced the first time in.
I have an EPS available if anyone wants it.
YMMV
Cw
I wish... If i did I'm sure my work shop would not be as ghetto as it is!
Chances are when your support failed it bent the shaft... it's possible... usually on the turbos with mods done to them.
I'm not aware of the solid aluminum shaft upgrade or how it would be installed ... there must be some give somewhere? How much did that set you back?
Been perfect since install.
And no mods when failure occurred. Was actually driving across country from purchasing. Stopped and did the Jimi-fix. Which also did not work well. Unfortunately.
I don't get why anyone would do anything for this problem except the Jimi fix. It's cheap, it's easy, it's fast. It costs less than a trip to MacDonalds, a monkey could do it, and you can literally crawl under the truck and be done with it in the time it would take you to limp the truck to your mechanic.
Mongler, tune down the derogatory attitude and comments toward other members or well give you some cool down time ...
There is more than one way (probably 4 or 5) for owners to resolve this issue and personal preference and cost dictates what's right for any particular owner. There are Jimi-fixes out there with over 100k miles on them and no issues, so that's clearly more than a band-aid type repair.
The solid replacement driveshaft is the most expensive way to go, but also has essentially zero future failure points. Here's what that looks like in case you're curious.
My Cayenne is a family vacation car and one I'll have forever, so anything I can replace to prevent a future failure while I'm 1,000.miles from home I tend to do.
It's the same reason I replaced the plastic intake plenum with a metal ipd one, as the plastic ones all crack eventually.
Let's keep the discussion and information exchange civil and respect everyone's opinion moving forward. Thanks.
