Elec Tailgate struts HELP!?
Old 08-29-2022 | 02:35 PM
Mattler's Avatar
Mattler
Default Elec Tailgate struts HELP!?
Hi Guys,
Can anyone help me correctly identify the right part for my 2008 Turbo.
I bought 2 struts from UK and shipped them to UAE only to discover from my Porsche specialist that the left and right are different.
This is what I bought which I think is fine for the right hand side
This is what I`ve bought already x2
However when I`m looking for the correct left hand strut the descriptions vary based on part number #955 512 550 07 Below are my 2 options found so far. Can anyone confirm either are correct?
This is an aftermarket offering from Ebay USA
These are used from Ebay UK but I`m curious about the hydraulic lines. They dont look like they are removable which then makes me think the previous pic is an incorrect part???
Old 08-30-2022 | 10:58 AM
Mattler's Avatar
Mattler
Anyone?
Surely someone must have the knowledge on this as apparently its a common failure?
Old 08-30-2022 | 12:51 PM
slavie's Avatar
slavie
Do you have a motorized tailgate? In that case, you only have 1 strut on the passenger side. The other strut is the motor, and does not need to be replaced unless if fails to open and close the tailgate.
What is the problem with your tailgate?
Old 08-30-2022 | 02:10 PM
Mattler's Avatar
Mattler
Its motorised.
Old 08-30-2022 | 03:38 PM
phatz's Avatar
phatz
...Its motorised
Old 08-30-2022 | 03:49 PM
Mattler's Avatar
Mattler
It tries to lift, seems to be too weak then beeps at me. It now only raises around 6"
Old 08-30-2022 | 06:37 PM
tomhartzell's Avatar
tomhartzell
This is a classic sign of a weak battery. One test for Cayenne batteries is to try to raise and lower the rear hatch three times. If it fails to raise or lower at any time, battery is often the cause.
phatz (08-30-2022)
Old 08-31-2022 | 03:20 AM
Mattler's Avatar
Mattler
I has a brand new battery
