Help with codes
CEL was on, so read the codes using Icarscan.
0174 - Bank 2 to lean
0171 - Bank 1 to lean
1559 Power supply without engine operation
It was smoking at startup, but generally running fine. I decided to replace the air-oil separator. When I removed it, the old one was torn, so I thought I was on to something. Put the new one on, cleared the codes, and started it up. The CEL comes on instantly.
0174
0171
1559
and now
1081 - Air mass ahead of throttle valve, partial load
1094 - Air mass ahead of throttle valve, implausible
I chose to replace just the diaphragm and cap, not the entire thing. After getting codes, I sprayed some starting fluid around the cap, and no change in the engine speed or tone.
Where should I look next?
0174
0171
1559
and now
Smoke test the intake. Sounds like you're getting unmetered air into the motor from a leak or cracked hose.
Also, I've seen where those diaphragm kits don't actually fit properly but no pwrisnal experience with them.
