957 Engine Transplant Parts List
Old 04-22-2021 | 07:18 PM
Davebrossi's Avatar
Davebrossi
Default 957 Engine Transplant Parts List
I may be doing a redundant thing here, but as I am hoarding components in to replace my scored CTT motor, I decided to keep a list of what's been ordered. Why am I sharing this? Well, honestly, if anyone has to go through this down the road, maybe this will serve as a helpful list for you to put together as part of a shopping list. Might also help you budget. Most of this has been about preventative maintenance without what is generally agreed upon as a necessity in the process, an LN long block setup. So with the elephant in the room addressed, here's where I sit, missing a few pieces I imagine, but... it's been a very unhappy blur. Also I left off the crankcase breather lines, and coilpacks/spark plugs since those are all being pulled from the current motor as they all have less than two thousand miles on them. There are a couple bundle 'kits' there with things like radiator, PS cooler, A/C Condenser rolled into one.
-oil pan gasket Audi Porsche VW Auto Trans Oil Pan Gasket - Elring 429.960 13.39
-front seal Porsche Engine Crankshaft Seal - Elring 510.870 118.89
-rear main seal Audi VW Porsche Engine Crankshaft Seal - Corteco 20027584B 13.49
-valve cover Porsche Engine Valve Cover Gasket Kit - Reinz/Elring 711192200KT1 182.48
-accessory belt/pullies Porsche Accessory Drive Belt Kit - Continental/INA 955BELTKT1 343.48
-water pump Porsche Engine Water Pump and Thermostat Kit - Geba/Mahle/Genuine 955COOLKT 356.55
-air filters Porsche Engine Air Filter Kit - Mahle LX792KT 31.38
-fuel filters A2C59514938 97.89
-Engine Mounts Porsche Engine Mount Kit - Lemforder/Genuine Porsche 3578801KT 245.36
-Water Manifold O-ring 900-123-131-30 -Porsche OEM 1.98
-Plug 900-219-004-01 Porsche 3.86
-Reservoir Hose 955-106-277-10 OEM 33.14
-Connector Hose Bracket 955-110-325-00 OEM 2.07
-Connector Hose 955-106-261-00 OEM 22.01
-Vent Hose 955-106-251-00 OEM 13.84
-Inlet Hose 955-106-323-10 OEM 20.78
-HVAC Heater Hose 955-572-587-02 OEM 8.60
-Engine coolant temperature sensor 997-606-420-00 OEM 34.22
-Engine Coolant Pipe 955-106-310-00 132.56
-Coolant Vent Line (3-way) 948-106-026-04-M58 OEM 49.00
-Gasket - coolant distribution tube to cylinder head 948-106-154-01-M30 x2 9.00
-Gasket - Exhaust Pipe (pre-cat) to Final Cat 955-111-113-10-M138 A.M x2 16.00
-Porsche Radiator Kit SKU KIT-955RADKT 291.67
-Porsche Power Steering Cooler Kit KIT 376726311KT 147.67
-Audi Porsche VW A/C Condensor MAH-AC659000P 213.79
-Porsche Radiator Coolant Hose kit 955RADHOSEKT1 111.60
-Porsche Expansion Tank Kit KIT-EPT0140KT 121.56
-Porsche Fuel Injector O-ring GER 99970760640 x 8 15.76
-Porsche Fuel Injector Seal ELR-005980 x 8 17.12
-Porsche Charge Pipe Seal 95511072000 x 2 8.52
-Porsche Engine Coolant Pipe 948-106-069-10 134.95
-Porsche Engine Coolant Pipe 948-106-061-07 304.99
-Porsche Exhaust Manifold Gasket ELR-265810 x2 27.76
-Porsche Alternator Coolant Hose 948-106-355-06 19.39
-Porsche Engine Coolant Hose 955-106-073-00 73.19
-Porsche Engine Coolant Hose Flange 948-106-462-00 14.19
-Porsche Engine Coolant Hose 948-106-383-50 16.59
-Porsche Engine Coolant Hose 948-106-05151 148.39
-Porsche Engine Coolant Pipe 955-106-310-00 132.56
-Engine Coolant Temperature Sensor 997-606-420-00 34.22
-HVAC heater hose 955-572-587-02 8.60
-Inlet Hose 955-106-323-10 20.78
-Vent Hose 955-106-251-00 13.84
-connector Hose 955-106-261-00 22.01
-Connector Hose Bracket 955-110-325-00 2.07
-Reservoir Hose 955-106-277-10 33.14
-Plug 900-219-004-01 3.86
-water manifold O-ring 900-123-131-30
-Porsche Engine Coolant Hose 948-106-051-51 148.50
-Porsche Engine Coolant Hose 948-106-355-06
-A/C System Retrofit Kit 559-807-901 14.39
-Porsche A/C Expansion valve EGE-165-100-23 49.79
-Porsche Receiver Drier MAH-AD212000P 42.39
-A/C Compressor Oil (1 Litre) 38.39
-Porsche 4.8litre V8 Twin Turbo Salvage Motor w/Turbos, 75k miles, VIN matched with mileage and matching Alternator, A/C Compressor; 4670.00
The Y-pipe in front is new, that much I know. I have 'estimated' (meaning probably no idea) 25-30 hours labor. My Mechanic's shop has done everything from 911Es and R8s to RS6s, Ferraris (yes, In Potato land) and ancient Mini coopers from BL. That's why the labor is light as it is.
Old 04-22-2021 | 07:23 PM
TRINITONY's Avatar
TRINITONY
water distributor or pin the one's that there, and oil pressor sensor, vacuum pump or change pump seals, CPS...anything that's normally a PIA to get to ...
Old 04-22-2021 | 07:28 PM
Davebrossi's Avatar
Davebrossi
Oh water distributor is on there :-) as well as the hoses alongside it. As well as the updated main coolant line that runs under the intake manifold (Porsche's update was to go from plastic to aluminum) the Vacuum pump's in the wheel well isn't it or is there another one?
Old 04-22-2021 | 07:31 PM
Davebrossi's Avatar
Davebrossi
948-106-061-07 Porsche Engine Coolant Pipe (that is the PET description). No pinning for me. The 'updated' part has that barb fixed in place.
Old 04-22-2021 | 07:35 PM
TRINITONY's Avatar
TRINITONY
https://www.pelicanparts.com/techart...eplacement.htm
Old 04-22-2021 | 07:46 PM
Davebrossi's Avatar
Davebrossi
94811005007. Bugger. Well, it's a good thing I'm out weeks still. Also the purpose of this thread. Crankshaft Positioning Sensor, Oil Pressure Sensor. Got it. I am hoping for good news about HVAC lines being usable, but imagine that's going to be an issue. Turbocharger components as well. Waiting for the worms at this point
Old 04-22-2021 | 07:51 PM
Davebrossi's Avatar
Davebrossi
on hand but not listed are LiquidMoly products (beyond Ceratech) two oil filters, engine additives (again LM) coolant, lots of coolant, correct PS fluid, and I was serious when I said there are a lot of things just labeled Porsche Engine Coolant pipe.
Old 04-23-2021 | 12:46 PM
Davebrossi's Avatar
Davebrossi
Another day, and more parts added;
-Porsche Brake Vacuum Pump PIE-701219170 151.44
-Porsche Engine Oil Pressure Switch BOS-0261230147 43.49
-Porsche Camshaft Position Sensor O-ring BOS-1230210027 .52
-Porsche Engine Camshaft Position Sensor BOS-0232103092 26.39
....I want a free T-shirt from FCP Euro at this point (No, everything is priced reasonably, yes they're helping me out here, just an always look on the bright side of life *whistles*)
Old 04-23-2021 | 03:00 PM
TRINITONY's Avatar
TRINITONY
Might as well as look at the O2 sensors and kitty condition....
Old 04-23-2021 | 03:35 PM
Davebrossi's Avatar
Davebrossi
I expect them to. That may be a situation where I consider salvage (only talking about the cats here) if they're as degraded as I imagine they're going to be (given how things have gone so far.) The Salvage motor comes with pre-cats already installed (which is nice) and even the exhaust headers look, dare I say it, -clean- which is pretty cool. But aesthetics count for nothing if they're filled with dirt daubers in the end.
Old 04-24-2021 | 07:30 PM
TRINITONY's Avatar
TRINITONY
and engine mounts....
Old 04-24-2021 | 09:03 PM
Davebrossi's Avatar
Davebrossi
Engine mounts were first on the list and part of the largest order I placed out of the gate. I am -hoping- (but this, like seals and accessories for the Turbos is probably going to bite me) that I can hold off on upper and lower control arms, tie rod assemblies, and wheel bearings. I'm at the right mileage where -all- of that is due to be serviced, and honestly that was my plan for the summer. Unfortunately Cylinder 8 had other ideas, so I'm pushing them out.
Again, I am extremely grateful for things I know I'm going to miss/forget here. Yes I know they're not engine items, but they -are- 'while you're in there' and while I can pull hubs and take them somewhere to have new bearings installed (which is how I had planned to do that and then change out the control arms and tie rods) it'd be nice to save that for another day.
Also; one -really weird- observation. The Water Manifold has several unused outlets. That's not the weird part since I know the powerplant is a shared motor. What -is- interesting is that the plug used these lines is the same part number as the oil plug.
TRINITONY (04-24-2021)
Quick Reply: 957 Engine Transplant Parts List
