Porsche Cell Solution For Cayenne
#92
Is this just a "hands-free" system or does it increase the phone from 0.5 watts to 4 watts with an external antenna?
So far no Nextel so I'm a waiter as usual.
#94
analyst
The Porsche cell phone brochure is now posted on www.RennTech.org, in the public area. This brochure states that this phone is not compatible with PCM, twice.
But this brochure also states: "... requires a dealer prep kit that integrates with the analog audio system or the fiber optic digital bus featured on all new Porsche models."
The only information available to date is for the analog interface. The question is, why would they offer a MOST interface if it doesn't work with PCM?
It may be that this is the result of Marketing "translating" information provided by Engineering.
#95
The picture I posted earlier showing the phone mute was the TBH System 8 installed. I was wrong about the cullmann system, unless Porsche is going to use them for the MOST solution. My guess now is that there will be a separate MOST to VDA box available soon, but the only thing it will add is the voice through the sound system. You can install any system you want now, but you have to find a place for the speaker. I took the TBH system out recently and replaced it with a SonyEricsson Bluetooh system that works very well. I have been thinking about simply wiring the sound into one of the sound system speakers since it mutes the PCM sound when a call is active. There are rumblings about a Porsche Bluetooth option. You have to figure they are working on a solution because Europe has a number of laws regarding driving and cell phones.
#96
Super Moderator
Needs More Cowbell
Needs More Cowbell
Please be aware that wiring directly to the speaker may not give the expected results.
When a 'Mute' command is set, the DSP in the amplifier merely clocks out zeroes to the output DAC's, which of course are connected to the linear output amplifiers which are connected to the speakers via the wiring harness.
The output amplifiers are still connected to the speakers and are still active, they are simply amplifying nothing.
Depending on the output source (differential/floating or single ended/grounded) you are connecting in parallel with your speaker, your results will range from unwanted noise/hum to shutdown/damage to the amplifier (the output amplifiers are protected against shorts to battery or ground, so you're unlikely to be able to cause permanent damage)
#97
Good point. I had done that in an Audi once using a relay. I read all the instructions several times and we are missing the VDA box in our US Cayennes. There will have to be a MOST to VDA box under the passenger seat.
#98
That will MOST (sorry, pardon the pun.... couldn't resist!
) likely be the Electronic Control Unit mentioned in the Parts Information Bulletin as PNA 180 004.
Toby
Toby
#100
johndjmix,
All parts are not yet available from PCNA. We're still waiting on the Man Kit and ECU box. There are several cradles that have PCNA part numbers, but I'm not yet aware of anyone that has tried to order/actually buy one. I have my kit on order. Already purchased the Prep Kit. Just waiting for all remaining pieces to come in so I can have all work done at the same time to keep labor costs down (note, I did not say reasonable!).
Toby
Toby
#102
Not yet. I will try to check in tomorrow with them and see. However, I head to Rennsport Reunion II tomorrow night, so it may be Monday before I have any additional details.
Toby
Toby
#103
Super Moderator
Needs More Cowbell
Needs More Cowbell
Mudman2,
I just received my "REVISED" copy of Porsche Talk magazine, along with a cover letter stating there were errors in the latest issued.
It stated that the cellphone kit worked with NO PCM systems (Boxster, Carrera or Cayenne).
Perhaps this is what your dealer was referrring to
(from an amplifier perspective, there is no difference between CRD23/0 and PCM; therefore this must be a headunit issue).
Wondering if anyone else got the same thing?
#105
Originally posted by ltc
Mudman2,
Mudman2,
however, input is limited to 1-2 channels depending on the install (right / left door speakers)
so....
