957 GTS Entry and Drive
So I got this issue for a while now, on the drivers side with key in my pocket and car locked I touch the door handle and nothing happens, I pull the door handle and the door unlocks, I pull the door handle again to get in. On all other doors as soon as I touch the door handle it unlocks.
Also I can never lock the drivers door from the door handle button, I press it and nothing happens, touch any other door handle button and car locks.
I have a VCDS on order so when that arrives I can probably look at it but until then anyone run into this issue ?
Do you have a keyless entry option? I'm not familiar. My 2010 GTS doesn't. I need to unlock with the remote before entering.
Sounds like the driver door unlock button is broken.
