MAF sensor wiring
Hello
Thinking of using a Cayenne MAF (Bosch 028218071) on a Porsche 944 and match the signals somehow.
Does anyone happen to have the wiring(pinout) diagram of this part? Any idea where I can get its maps?
Haim
Haim
Don't different MAF sensors have different ranges out output voltage based on the airflow? I'm not sure you'll get the right range of signals using a different sensor even if you map the signal wires correctly.
You are right, I am thinking of adjusting the outputs using an Arduino or something similar
