low dust brake pads
low dust brake pads
Hi there,
I find fascinating how discussed this subject is and how little it is settled.. so the deal is that I live somewhere with rather low temps... so a lot of the great performance pads are questionable under extreme starting winter conditions ( hawks, redstuff, yellows?).. my attention has been shifting towards ATE ceramics or TRW ceramics or even like a Reysbestos Element3 (they also have the European Speciality line).. does anyone have any better suggestions or corrections to make?
I am getting new Zimmermann routers (I have a second car also - BMW 6 series.. for that going the Akebono EURO ceramics route..)
1 - low dust
2- strong initial bite in cold weather (all street use, dont care for track)
3 -def no noise
many thanks to all!
1 - low dust
3 -def no noise
many thanks to all!
Last edited by deilenberger; 09-30-2020 at 10:58 PM. Reason: OCD caused me to change break to BRAKE in the title..
I am in the NW so not too cold with the winter, but I did replace my pads with TRW ceramics and so far, so good. I'm nuts for keeping my cars clean and have always had Akebono pads. However, they don't make them for my 09 CTTS. TRW was the ones I decided to try. Zero noise, very low/no dust and I'm happy with the bite and performance. Good luck!
Cheers
Cheers
deilenberger (09-30-2020)
I put TRW ceramic on the back with Bosch coated rotors. I live in a northern climate.
Initial bite and stopping power are both good but they occasionally squeaked. It's possible that it was sand/gravel related from winter roads, or temperature. Powerwashing would make the squeak go away for a while but it came back occasionally. The squeak annoyed me in the spring but I haven't heard it for a few months.
Akebonos are fine and def less dust. BUT are not as good overall performance wise as EBC Yellows. I switched on two cars and the results are the same. Yes, I will stay Akebono for less dust and pad life, but they are not the best if you are after performance. Neither of those cars are "fun", so I don't care.
For the CS I am sticking with the stock dusty pads because they work.
