4.8 Turbo air oil separator
Hey all,
Has anyone found a good replacement AOS for the 4.8 turbo? I bought the usually referenced IE works cap but the cap seems too small to click back on. The feedback online includes a bunch of doesn't fit turbo comments.
I'm currently going through a similar process. Have a 2008 957 Cayenne Turbo, same as you.
I ordered the one from VANOS BMW in Russia, it took a couple of weeks to get here and looks very similar, but appears to be a 'hair' too small and thus is very hard to make the cap fit properly. There's also a whistiling from the AOS area (was there for a little while before I changed it), but I also found a disconnected vacuum hose on the other side of the engine near the firewall, which may be related to the whistling.
The car is currently at the mechanic for a few jobs. I've tried to get them interested in fixing the vacuum/AOS problems, but not having much luck (the most pressing issue is a leaking fuel pressure regulator).
Anyway, in the meatime I've ordered the 4.8L diaphragm from KLA Industries in the USA. Hopefully that will be the correct fit. It'll take a couple weeks to get to me.
If that also fails to fit, I'll simply order the factory plastic cover with the integrated AOS (TBH - that's what I should have done in the first place. I've already spent around 100 USD on the diagphams, and the factory part is around 200 USD I think).
You can look at my other posts for my rambings on the subject!!
let me know how you get on.
Below a picture of my old and new diagphams.
Russian VANOS-BMW product underneath the OEM AOS
for the 4.8 turbo I believe (and yes I know this sounds weird) the cap/membrane from a 4.5 litre V8 is the alternative to use. That said, the fact that I ended up going straight to the full plenum and down the rabbit hole of crankcase lines after that shows my level of finesse :-)
After all this time, has any proper replacement come around instead of purchasing the entire $200 housing just to replace the seal? I do see mention on Pelican's installation thread, that a BMW Vanos retailer out of Russia sells the seal alone for like $20, but is this place out of Russia still the only option?
Surely there must be a viable option somewhere here in the states now?
TRINITONY (08-13-2024)
Thank you for the recommendation. My cap I believe is cracked from when I attempted this a few years ago, I don't suppose places sell that cap too? The one I purchased off of Amazon a long time ago was too small for my 08 Turbo.
