Engine Overhaul/Tips/Recommendations
5th Gear
Hey guys,
I'm a 17 year old in Las Vegas, NV and I picked up this 955 2006 4.8L V8 Cayenne Twin Turbo a few years ago from auction as a project car which currently has approx. 145000 miles on it (pics of it attached). I am currently in the process of doing a massive overhaul to make this engine practically brand new and am about to haul the engine out due to a blown head gasket and a recent severe knocking coming from the top end of bank 2 which increases in noise with RPM's (video of knocking attached lmk what you think it might be). I took off the front bumper to do some paint correction and to fix front fender damage on the passenger side I made when I bumped my wall. Any tips or recommendations on taking out the engine? Also if anyone can go into a deeper detail of how the engine is bolted onto the frame and any tips on how I should go about pulling it and if its possible to just do the head gasket without pulling the engine out that'd be greatly appreciated, thanks guys.
Front
Back
Car currently
Here is a video of the car knock
Front
Back
Car currently
Before investing another penny into it, check the cylinders with a borescope camera.
The engine/transmission are installed at the factory from the bottom and that is how the shop manual shows removal. You just drop it out the bottom on a lift with the suspension/brakes and engine cradle all in place along with the front Diff. I think what 19psi is alluding to in the bore inspection is the possibility of bore scoring. Did you run a compression check before you started pulling things apart? Bore scoring isn't as prevalent in the Turbos but it still happens. BTW, yours is a 4.5Ttt, the 4.8tt came out in 2008 in N. America.
5th Gear
The engine and trans can come out the front with it in service position like you have it now. If you don’t have a lift, that’s how it’s done.
Also, get a copy of the factory service manual online or get a subscription to alldataDIY. You’ll need a lot more info than you’re going to get on a forum and it’s all in there.
5th Gear
5th Gear
Edit - Yep, I have a subscription to alldata.diy just gathering as much information as I can to make sure I don't screw anything up.
Take my advice with a grain of salt, as I haven’t pulled a 955/957 engine before. But I doubt it’s easier to remove just the engine. It’s pull front axles and other components vs getting to the engine to trans bolts. I would rather pull everything then replace all seals and mounts before reinstalling.
BobcatBrian (08-12-2024)
