HVAC Actuators -- How to bench Test
Old 06-15-2020 | 05:42 PM
  #31
Marv's Avatar
Marv
Originally Posted by deilenberger
Snippage of some text and pics to shorten this up..
Exactly. Isn't that what I said?
Sorry. I misunderstood. I thought you were saying they were all the same and if they weren't it would complicate everything. Not that things aren't complicated enough with a Cayenne.
Old 06-17-2020 | 09:58 AM
  #32
BlueOvalKid's Avatar
BlueOvalKid
Originally Posted by Marv
Well, my HVAC doesn't work with the engine or with the car off, but that's because my servos are missing and what ones I still have are bad. However, the controls will work with the engine off and the key in the ACC position.
I would start by reviewing your work to see if there is a connector not seated or missing. Then I would consider the fuse on the passenger size.
Keep asking yourself what changed. Something changed to cause the condition.
I had tested the 10A fuse for the HVAC and it passed a continuity test. I did pull it though and replace, just for SnG, and the HVAC fired right up. Thanks for the reminder.
Quick Reply: HVAC Actuators -- How to bench Test
