Warning chassis system
Old 04-18-2020 | 10:10 AM
samp1's Avatar
samp1
7th Gear
Default Warning chassis system
2008 turbo, I just rebuilt the compressor and reinstalled everything, started the car and received "warning chassis system" compressor doesn't run. Does something need to be reset?
Old 04-19-2020 | 09:31 AM
Petza914's Avatar
Petza914
You can easily disconnect the battery ground then after 10 minutes reconnect it. That will reset anything that's easily reset.
Does the car have PDCC. A chassis system message can also be related to that subsystem.
How's the fuse for the compressor?
Old 04-19-2020 | 04:49 PM
samp1's Avatar
samp1
7th Gear
no PDCC, checked fuses both ok, disconnected the battery, error still exists and compressor doesn't run.
Old 04-19-2020 | 08:39 PM
hatchetf15's Avatar
hatchetf15
OP - Did you put a Durametric on it? Also, last thing touched, first thing checked?
Quick Reply: Warning chassis system
