cayennne flashing lights
Old 03-23-2020 | 12:42 AM
james_085's Avatar
james_085
Default cayennne flashing lights
just had a look at a cayenne that is up for auction but has some lights flashing as pictured, just wondering if anyone could tell me what it could mean ?
Old 03-23-2020 | 01:34 AM
phatz's Avatar
phatz
sleeper cell alert
Old 03-23-2020 | 10:12 AM
Petza914's Avatar
Petza914
That's the Differential lock control toggle for off road, mud, or snow use. If someone locked the differentials with that toggle and then drove on dry pavement, they've probably damaged them and that's why it's flashing. Any error codes stored?
Old 03-23-2020 | 06:27 PM
Mark7000's Avatar
Mark7000
If it is up for auction, I bet some idiot simply pressed the switch to see what it does and did not drive the vehicle at all or tried to put it back to normal drive mode and did not backup the vehicle to get it out of low range. I doubt there is any damage.
Old 03-23-2020 | 06:47 PM
nodoors's Avatar
nodoors
Those lights mean, "Best of luck to you!"
Old 03-23-2020 | 08:31 PM
slavie's Avatar
slavie
Each light represents a single unit of dollars, in thousands, your local dealer is about to make off you. Lights are usually accompanied by corresponding friendly messages on the dash, to lube you up a little.
Old 03-23-2020 | 09:14 PM
phatz's Avatar
phatz
Join Date 2005
1 Post
Old 03-24-2020 | 12:12 AM
TomF's Avatar
TomF
If the doors locked automatically, and the car begins to fill with gas, then shortly you will hear: "Goodby Mr. Bond."
Quick Reply: cayennne flashing lights
