PCM software upgrade
Anyone notice when they brought the truck in for the software upgrade, the stereo sound(sound button) options changed??? I used to have a surround sound feature and that is now gone. It's been replaced by the loudness option and the other previous option...I forget what it was called has been replaced with Dyn. Volume... Anybody notice this??? I am happy with this change...Just want to make sure that I am not imagining anything...
Originally posted by mudman2
Chris
What version of SW is it showing, mine still has surround on 3.0.
Mike
Chris
Mike
press main and trip at the same time
System 2.0
Strange. Which button do you press to set surround?
I did not see it under audio or sound buttons, but I know I had it at one time...
Sound button now offers these options only:
bass
treble
balance
fader
loudness
Dyn. Volume
I could have sworn that the surround option was offered there...
Something was changed since my clock is no longer in 24hr mode....
Moderator !x4
You might know the technical term Chris.
Same as when you hit your pinky with a hammer, ****ed
They did a TSB fix but did not upgrade the the PCM / Bose AMP (seperate TSB). Also sounds like its lost some of its function, bad use of PST-2 can cause this.
Bear in mind you will need 03 discs from NAVTECH.
A few months back, I had the PCM S/W upgraded to 3.0, and I just checked and I still have the surround function. The dealer did not perform the Bose TSB S/W update -- when I bring it in for the recall, I'll request this update.
Anyway, this update solved a couple of problems for me including delayed start or sound failure-- now sound system always starts up promptly. No more AM frequency shift to FM. I just read the TSB on the Bose update and it solves the sound failure problem that I had prior to the PCM 3.0 update. So, I'm not sure whether I need it or not, but I guess I should get it.
Originally posted by ljugete
Looks like you may have gotten downgraded! Get after the dealer to correct this ASAP. Good Luck!
Moderator !x4
I hear what you say but the dynamics in the cab is at best poor. I find the surround makes it more musical, albeit without a clear stable soundstage.
Having the sound in a virtual position about the head compensates for a lot of the ills of the less than perfect environment.
In other words I like it.
Mike
Mike
Mike
Mike
