955 Cayenne driver seat adjusters HELP!
Trying to get this driver seat adjuster issue sorted. Can anyone assist with some info please? I have 3 codes...........
1. 2332 Backrest angle adjustment sensor
2. 1916 Lumbar horizontal height adjust sensor
3. 1915 Lumbar vertical " " "
Does anyone have the tech info as to the location of these sensors before I start looking? Are they individual sensors in seat assy or contained in the module unit?
Thanks in advance,
T
Thanks in advance,
T
Sorry, no specific info. But if I had 3 sensor errors in one seat, I'd check for a single unplugged connector that hopefully wires all 3 sensors. Seems more likely than for 3 separate sensors to actually fail.
or possibly an old or weak battery since all kinds of weird errors show up on these vehicles when battery voltage is marginal. How old is the battery and were you recently doing any work under that seat where you may have dislodged a connector or not put it back properly.
Thanks guys, yes recent battery replacement not long before I purchased. Looks like someone has been "Playing" with seat concerned who doesn't know what they are doing. Seat rail plastic covers not on properly is a dead give away. Will need to get under there to see what's going on..........any trick to removing seat? Does it hinge/tilt back like the pass seat with battery under it?
