P/Ns for Hardware on Panels Below Engine
Old 04-02-2019 | 02:43 PM
ThomHart's Avatar
ThomHart
Default P/Ns for Hardware on Panels Below Engine
All- I have an '09 Cayenne GTS (manual) that I bought from a friend so I know its history and am confident it is well sorted. However he did not do most of the work on it and there are some shortcomings by other mechanics I am trying to fix. One of my pet peeves is that all of the original hardware be used in all of the original locations. Well, in performing an oil change the two panels that need to be removed, and the third that needs to be dropped out of the way, are held on by about 2/3rds of the needed screws and bolts, and what is on there is not all Porsche including some zip ties. I have been through the parts diagrams from Porsche a few times and cannot find the drawing to the two rear panels. Can anyone help me here? I did find the drawing for the front panel and was able to get the necessary hardware. However the panel on the diagram is metal and mine is plastic so still trying to get the plastic panel part number. I assume I am missing something but if anyone can point me to the necessary diagrams and the P/N for the front plastic panel I would be much appreciative. Thanks in advance.
Old 04-02-2019 | 04:28 PM
Libast's Avatar
Libast
Page ~398 of the parts catalog for 03-06
Page ~438 as noted in the catalog for 07-10
Old 04-02-2019 | 04:29 PM
NelaK's Avatar
NelaK
Check page 437 in the Cayenne (E1), 2007 - 2010 catalog.
I'm seeing the following fasteners for those panels:
Position: 9
Part #: N 910 345 01
Description: hexagon head bolt (combi) M6 X 20
Position: 22
Part #: N 908 338 01
Description: expanding nut 4,8 X 12,0
Position: 23
Part #: N 906 487 01
Description: Oval hexagon socket head bolt ST 4,8 X 16
Old 04-02-2019 | 04:30 PM
NelaK's Avatar
NelaK
I was going to say you beat me to it, but OP said he has a 2009, you linked the 2003-2006 catalog.
Libast's Avatar
Libast
Yeah noticed that after the fact, but they look to be identical parts as it is.
Old 04-02-2019 | 04:32 PM
NelaK's Avatar
NelaK
Shhh. Let me bask in the glory of being -technically- correcter
Old 04-02-2019 | 04:37 PM
Libast's Avatar
Libast
That's the best kind of correct
Old 04-03-2019 | 10:23 AM
ThomHart's Avatar
ThomHart
NelaK and Libast thanks for you help, it was indeed in the parts catalog I have access to ('03 to '06) and I missed it. Interestingly, I cannot download the E1, 2007-2010 Cayenne parts diagrams. Everything else is in the parts diagram listing on the Porsche web site except for the truck I have. So, if someone can direct me to another source that would be great, or let me know the P/N for Position 24 in the second diagram and I am good to go. Great resource here at Rennlist and I look forward to more Porsches and getting greasy with them.
Old 04-03-2019 | 10:47 AM
Libast's Avatar
Libast
955 504 199 00 bracket transmission carrier
if you PM me your email, i can send you the PDF for the 2007-2010
or if you trust me, I uploaded it here
http://s000.tinyupload.com/index.php...01147283347868
Quick Reply: P/Ns for Hardware on Panels Below Engine
