Can comfort on 2 wire?
Old 03-06-2019 | 05:47 PM
Hizus's Avatar
Hizus
Default Can comfort on 2 wire?
so I’m using icarsoft por2. I used to have can comfort on single wire fault and passenger door fault but found and repaired a corroded wire on the passenger door uk car. Re checked now I get can comfort on 2 wire. When I look at all other modules on the gateway I get OK For the communication. Should can comfort say 2 wire? Anyone had same faults.
Wiring loom on floor both both sides checked and have been repaired before. But I stripped joints again and made a better job and re sealed. Do loom is good.
Quick Reply: Can comfort on 2 wire?
