Odometer Trip Button
Old 03-04-2019 | 11:34 AM
acer54's Avatar
acer54
Default Odometer Trip Button
The trip button when pressed does not zero the odometer reading, I know that these often fail, can it be repaired or is it better to buy a new button from Porsche at probably an extortionate price?
Old 03-04-2019 | 03:27 PM
kadn33's Avatar
kadn33
I fixed both buttons with a credit card and epoxy: cut a trinagular piece of old credit card or similar, something that will not bend when pressed against the cluster, and glue it with the epoxy where the button starts to be hollow underneath, following its shape. Just look at it and you will understand. Use the epoxy to fill the rest of the area and you are done. Let it cure, trim any plastic or expoy if necessary and back to the cluster.
Old 03-05-2019 | 08:01 AM
acer54's Avatar
acer54
Originally Posted by kadn33
I fixed both buttons with a credit card and epoxy: cut a triangular piece of old credit card or similar, something that will not bend when pressed against the cluster, and glue it with the epoxy where the button starts to be hollow underneath, following its shape. Just look at it and you will understand. Use the epoxy to fill the rest of the area and you are done. Let it cure, trim any plastic or epoxy if necessary and back to the cluster.
Thanks for the heads up, I'm going to drop to the Stealership and see what they cost new (probably need a small mortgage lol)
Old 03-07-2019 | 09:44 AM
acer54's Avatar
acer54
Cost's £41 - Robbery With Violence!
Call me old fashioned but I bought one.....
Now fitted and working!
Quick Reply: Odometer Trip Button
