I bought a Y charge pipe and seal from Porsche as I know they're a common fail and if I'm going to book my CTTS in for a smoke test, I'd be annoyed if that was it. Now I'm not convinced it is that, but its worth it for peace of mind and at least removes it from the list of suspects. So went to fit it today, the screw when transferring the sensor took some effort to screw into the new pipe. The old pipe had no date on it, but the new pipe was stamped with a date in 2017, so perhaps the old one is the original one.
I found that one of the vacuum pipes has been rubbing on the pulley, so that's looking like a good culprit for a vacuum leak
How do you remove the metal clips (not the upper metal squeeze clips) off of the pipe that runs to the (what I think is the) purge valve?
Thanks How do you get these metal clips off ! I'd say this could be a culprit for vacuum leak, its clearly been rubbing on the pulley!
