Instructions on how to install the spare tire...
collasable spare install
I watched the service tech install mine..5 minutes at the most. you first must fully remove the pull up carpeted cover or it gets in the way. The pop rivet screws into the existing bolt in the bottom of the space. This will connect to the rod that goes up thru the spare and holds it in place. Then simply hook up the rod, place the spare over the subwoofer assembly, and secure the spinner on top to hold the tire in place. Absolutely no drilling or alignment troubles. If its taking more than a couple of minutes you are doing something wrong
