Diagnostic Tool
#31
Air quality sensor is a common fault - replaced mine and fault code went away.
From a previous post -
Got the cabin auto recirc working again and cleared fault code 1592 by replacing the air quality sensor.
it’s a VW part, common to many vehicles. 7l0 907 643 and has been superseded by the same part nunber with an A at the end 7l0 907 643A
This thread helped to find it.
https://www.renntech.org/forums/topi...-is-this-part/
Edit
Edit
"The air quality sensor monitors ambient air pollution and sends a signal to the Climate Control Unit. The control unit will command the recirculation flap to close if the concentration of pollution is excessive. The air quality sensor reacts to oxides of nitrogen (NOx), Carbon Monoxide (CO) and Sulfur Dioxide (SO2). The air quality sensor is in the fresh air inlet on the left side."
Sounds like it's not too urgent. AC works fine. I'll take a look and at least make sure it's plugged in. The PO had the front bumper repaired at a body shop, and they were much better at the body work than the associated mechanical work. BTW, the bumper was a front ding from being backed into while parked, so probably not related to the airbag control module.
Here's an example of a fault that was not reported by OBDII, and was completely unknown to me before the Foxwell.
#32
My check engine light came on last week (vehicle still runs great) so read codes with iCarScan X431...so now I know enough to be dangerous. Where do you go for further detail on the codes produced? I'm using the Porsche module on the iCarScan and have identified my vehicle to the code reader with the VIN. Would the same error codes be similar across all Porsche vehicles or specific to our Cayennes?
I've produced these codes:
- P1284 "Fuel pump else fault"
- P000A "Intake Camshaft slow respones Bank 1"
- P1572 "Control Unit run on not ended correctly"
#33
Thanks for sharing, this helped me decide to give it a try myself and just wanted to confirm the Foxwell NT520 Pro works great on my '08 GTS. I bought it from Amazon and it came with the Porsche software pre-installed. Just plugged it in, auto-detected the vehicle by VIN, read Porsche codes, and reset my vehicle service reminder. I haven't played with the more advanced functions yet but just for the above and being a general purpose OBDII scanner makes it a great value compared to the Durametric tool (costs about 2x as much, Porsche only, and VIN locked to 3 vehicles).
#34
The best is the Porsche PIWIS - $15,000/year rental from Porsche. It's the best available and will do the most things.
Alternatives are Durametric ($300 for 3 VIN#'s), iCarScan ($200 for unlimited VIN#'s and 5 different manufacturers.) Neither is the equal of the PIWIS, but they are a bit more affordable.
Many thanks,
T
#35
Received 1,153 Likes
Don, looking at a icarscan x431 you have recommended. Having issues with my 05 Cayenne air suspension (can't drive the car :-(. Can you suggest a reputable supplier at a reasonable price please? My problem is I'm located in Australia. The link on your thread takes me to a site that my PC security doesn't like or is that the best site available?
Many thanks,
T
Many thanks,
T
Good luck!
#36
Hi Don, appreciate your reply you seem to be pretty familiar with this tool and happy to give it a go as it does most things including recal air suspension which I feel is needed for these cars.
Thanks again Don,
Regards, T
Thanks again Don,
Regards, T
#37
T - I'm a bit hesitant to recommend a site since it's been 3 years since I purchased mine. The error message you're getting going to www.obd2tool.com - is due to their security certificate has expired. That probably isn't a concern if you pay via Paypal (which is an option) - since the payment will all be done on a secure Paypal website. Other than that - Amazon lists it - perhaps for a few dollars more - but at least with Amazon it's easy to return if it doesn't work for you. There is also http://www.x431tool.com/wholesale/x431-diagun-dbscar-bluetooth-connector.html - and I'm uncertain what their relationship with Launch is - this particular tool is rather obviously using Launch software - perhaps licensed by a secondary company.
Good luck!
Good luck!
Thanks in advance,
T
#38
If you bought the icarscan tool - the software is available for android or iphone. It's called "EZDiag" - and you download it just as you would any other software. You then have to setup an account and register that account to your OBD-II plug adaptor (each has a unique serial number).. so - do you have the tool? (Question #1.)
#39
It's a Dutch "Zoobek" ECU-200 OBD/OBD2 scanner but unsure this will be compatible with icarscan tool. I'm a little confused here as NelaK on here who has also been very helpful said that I should receive the S/N that icarscantool are requesting (Before they ship my order) with tool when it arrives. Then use this number to log into device and down load the sofware..........does this make any sense? Trying to email icarscantool to clarify what I need to do. Thanks again for the help with this..........trying to get my head around it!
#40
#41
Icarsoft por2 is very good. Does resetting and injector coding.
I would say for the cost it’s a good diagnostic tool and resetting various special functions.
Its not as as good as high end obviously but you can see all modules so helps fault finding.
It’s also updated online very easy to do. I have done 2 updates so far.
#43
I just had no idea other I needed other devices with specific S/N's to be able to activate this tool as it wasn't mentioned anywhere on here so at least Iv'e highlighted this issue with this tool http://www.x431tool.com/wholesale/x431-diagun-dbscar-bluetooth-connector.html
#44
Yes so it seems.............not to worry, i'll get to the bottom of this eventually. Very difficult to sell someone a product, keep the $ and not send the product when PayPal used. I guess we'll see how good their buyer protection plan is?
#45
deilenberger (06-25-2019)
