Keys - Let's see if I got this straight...
I bet what gets a lot messed up is not choosing the correct MHZ that your original key/Cayenne used. There are two options and it is printed in micro lettering on the remote under the key blade when closed. Many of the ebay or china remote sellers do not advertise what MHZ their remotes are.
BTW, the remote FOB at the site I listed above is genuine Porsche
On mine it is in the slot that the key sits in when closed. The lettering is really small! The white may be worn off so you will have to clean it and get a magnifying glass probably.
I had this happen on one of mine too... using the key to start the Car solved it for me. I think that if the battery is out of the fob too long it drops it's 'pairing' to the vehicle
Key in the ignition and the chip detection reassigned things (as best I can tell)
Cheers,
MK
Cheers,
MK
I tried my original FOB and its the same thing > no chirp.
Thank-you, Coach 11
Cheers,
Tom
I have watched a few of the youtube videos that suggest it is possible.. and have been meaning to try to clone my one good key onto a brand new NXP RFID chip. if this works it allows you to key key cut and then skip the whole ordeal of pairing a new key to the car.
IF it works then same can be done to any of the aftermarket keys.. I assume that this is how the locksmiths who advertise ability to add a key do it. They clone your existing key to a blank one.
Yikes....what a mess. Still hoping the previous owner replies that he does indeed have that second key., service paperwork shows he bought an additional one in June 2017. Only one key here also.
The dealer went through three keys to get one which took the programming. Evidently the Porsche supplier has some quality issues. Anyway, because of the wait and inconvenience, they full boat comped me and fixed a marker light at NC. A loaner for a week worked too. Very pleased.
It appears there is a place in Staten Island (NYC, NY) that does 955/957 Kessy programming. I stumbled across an interesting video on YouTube showing them doing something with a Kessy.. involving soldering wiring to the circuit board.
The Kessy surgery:
Here is their general ad:
Maybe someone wants to check them out? If I had to guess - they might be from Eastern Europe.. (Russia perhaps?)
The Kessy surgery:
