957 GTS to Turbo Cluster Install
Re-opning an older thread. I did this swap, and love it. The issue is I still have a couple warning lights (headllight adjustment and TPMS). I am going to trade my Cayenne in and need to clear these. I just talked to my local Porsche dealer, and they flat out said they wouldnt do it.
So, two questions, can I get semi detailed instructions on what needs to be down for someone with PIWIS, and does anyone know of a shop in the Indianapolis Area that will do this?
I replied in another thread about this cluster swap. Is this odometer reset took a generic tool for different vehicles or is it specific to the cayennes? I’m looking for this tool as the turbo cluster I bought has 155k miles on it and my GTS has 128k miles.
Just came across this..... (no affiliation)
Seems the ultimate option, there seem to be a company offering just the install of the wide turbo center display into your existing GTS cluster getting rid of the amber. No need to deal with the mileage and potentially all the other features. I might definitely look into this, but for me one more potential issues, I have 6 speed manual, wondering what to expect with all turbo model have automatic. I contacted the seller, I will report back.
https://www.ebay.com/itm/274041581149
It's not what it appears to be. It's impossible to replace the monochrome display for a full-color one. The only option is to fit an entire Turbo cluster. The recoding is not difficult. Use a mileage adjuster tool to write the correct mileage to the new cluster, find someone with a PIWIS to write your car's VIN to the new cluster, then do a "handover".
Sorry for jumping on an old thread; I swapped my gts cluster for a same-year turbo cluster. And can’t seem to get rid of the tpms warning or even get it to recognize the tpms. Any suggestions you may have would be greatly appreciated
hey thank you for the suggestion, do you know anything about these piwis clones. I found some online for the Piwis 2 I’m wondering if it’s worth me buying it and just doing it my self
