Cayenne TT Drivability Problems
I am frustrated with my TT. Took it to the dealer for the update for the surging problem, as well documented in this forum. Now, the transmission seems to "hunt" for gears, often times shifting up two gears at a time, or downshifting the same way. Additionally, when in 3rd gear, the trans will not shift down to 2nd (for acceleration) below 3,000 RPM's, or above appx. 4,000 RPM's. Then when it does shift into second, the engine will easily turn up to redline and not seem to shift up to third, even when I let off the throttle. it just hangs there.
are these characteristics of the vehicle, or is there a potential programming issue with the shift points and "character" of the driveline. Also, is this a "learning" driveline that adapts to the nature of the driving style?
Appreciate any input or experiences before I try to get this resolved at the dealer.
I'm pretty sure that part is intended behaviour when you are driving the car hard, and I think it works very well.
Originally posted by mudman2
Agree Dan but do you thinks its just a bit confused also with the other things described ?
But to be frank I have been driving almost exclusively in M mode for the last few months...
After driving the vehicle hard, today, it is my conclusion that the character of the trans trying to find gears, etc is a function of "learned" driving behavior. The dealership told me that the transmission (as well as Audi) are adaptive. In that I have spent much of the first 2000 miles babying the vehicle, I guess I taught it to "underperform", resulting in the behavior as I described. After driving it hard today, the vehicle seems to shift more normally, and is quite responsive. Maybe I "fixed" my own problem! If so, the only downside is that I used a hell of a lot of gas (11mpg) proving that I can retrain the performance. But the result should be good. By the way, I have put EVO diverters on the vehicle, and if I keep the vehicle, an EVO DME mod will be forthcoming. Thanks for the input.
I am not sure about product liability, or how many complaints they have to have to issue a recall, but be patient the Cyanne's are awsome cars. But like every new car they have some issues.
Rob
