Speaking of Vacuum line broken connectors
So, anyone have a good idea on how to get this line separated from the Back side of intake manifold.
Last one I did like this was the bottom of the intact plenum and had to break the red parts out.
Leave it connected on the back of the intake and remove it where it connects to the rubber line that goes into the firewall. Much easier to leave it on and remove it with the intake manifold.
OK, any special technique to get this fitting off beside dremel carefully? Thought ma
OK, any special technique to get this fitting off beside dremel carefully? Thought maybe I could squeeze it in the right places and pull, no way.
