Hybrid system warning
I want to share a troubleshooting experience with a 2014 cayanne hybrid. I added some aftermarket parts to the electrical system (I know, frowned apon) in the midst of fiddling around in the rear compartment that houses the hybrid batteries I bumped the orange latch for the disconnect. Photo below. That set off a code on the dash called "hybrid system warning" the car would function normally except it would not start. Simply sliding the lever on the orange switch closed repaired it. 24 hours and two mechanics later.
