High Mileage ROLL CALL!
Old 04-25-2018, 11:13 PM
James1911
James1911's Avatar
113,000 on my 05 CTT. Purchased it 1 year ago next month... 109,000 when I drove her home from Alabama to Colorado. Hoping to get another 100K!
Old 04-26-2018, 12:43 AM
Travis
Travis's Avatar
192K and change.
Picked up at the end of 2012 with 149K for a small amount.
Its been predictable and reliable. Gone through a few of the usual suspects in terms of known issues. We’ve been very happy with it.
Old 04-26-2018, 01:14 AM
medtech
medtech's Avatar
Those friggin hatch struts!! I think I'm currently on my third set, or maybe fourth. But all in all maintenance cost has been within normal for a Porsche (about $1-2k per year avg)
I remember some of the gen 1 cars with 250k. I wonder what happened to them?
Old 04-27-2018, 01:22 PM
pbarch1
pbarch1's Avatar
77k, 2009 GTS, sweet sweet ride
Old 04-28-2018, 04:45 PM
Adam Conrad
Adam Conrad's Avatar
149k on my 2006 TT S Model. Replaced the coolant pipes, many many coil packs, rear hatch struts need replaced again, but overall not bad. Can't even think of what I would replace it with!
Old 04-29-2018, 12:24 AM
dorumac
dorumac's Avatar
For James 1911:
You did 4000 miles in a year, so for making 100k you need 25 years.
Old 05-05-2018, 01:33 AM
James1911
James1911's Avatar
Originally Posted by dorumac
For James 1911:
Yeah I plan on driving it a bit more this year.
Old 05-05-2018, 10:39 PM
cordsig79
cordsig79's Avatar
2004 CTT, 158k miles...........slick as can be...
Old 05-06-2018, 01:30 PM
hatchetf15
hatchetf15's Avatar
Still running great at 140,000 miles.
06 CTTS, all stock except for custom screens.
Old 05-07-2018, 04:49 PM
dhc905
dhc905's Avatar
I've got 186K on mine, now going into it's second set of coolant T's!
Old 05-08-2018, 02:30 PM
medtech
medtech's Avatar
Were the replacements aluminum or plastic??
Old 05-08-2018, 02:50 PM
Captain Scurry
Captain Scurry's Avatar
06 S 180,000 miles, all of the usual problems/repairs plus a few extra, but still going strong.
Old 05-08-2018, 06:29 PM
dhc905
dhc905's Avatar
OEM, so rubber. The first set lasted 90K miles. Second set, 94K miles. I figure I'll need more than coolant-t's for the next 90K miles
Old 05-10-2018, 03:40 PM
Douglas61
Douglas61's Avatar
59k now on my Cayenne 08 V6 base. I got it at 55k last year, did a Jimi fix and an oil change.
Old 05-19-2018, 12:55 PM
z064ddle
z064ddle's Avatar
140K on my 06 Cayenne S.
Services:
- Oil change very 10,000 miles.
- Coolant pipe swap at around 90,000 miles.
- passenger side secondary air pump replaced at 130,000 miles.
- Driver side Pre-Cat O2 sensor replaced at 110,000 miles.
- Spark plugs replaced at 90,000 miles.
- all 4 Brakes and rotor replaced at 43,000 miles due to previous driver aggressive driving habit.
- 2nd set of Front brakes only replaced at 125,000. The rear brakes is still in good shape.
- Took it to NTB and asked them to do a wheel alignment to my specs, so that the rear tire don't wear out so fast and loving it. The last set of tires had over 30,000 miles and still look new.
- Took it in to the dealer for a Fuel Pump filter flange Recall due to gas smell from the driver side rear fender at 140,000 miles. Currently at the dealer.
Schedule Services:
- All fluids - Differential, Transmission, and Transfer case. Hopefully this will fix the 4-wheel drive faulty code.
Quick Reply: High Mileage ROLL CALL!
