2006 Cayenne S Titanium CEL P1116
4th Gear
I did a search of the site and did not find any threads about the trouble code P1116. I have a Durametric diagnostic tool and it says this code means the coolant temperature sensor is faulty. I replaced the sensor and reset the code. The check engine light went out and came back on in 10 minutes. I don’t know what to do next. The car runs well but I have to pass the emission test in a couple months. Any help you guys could offer would be appreciated.
Received 1,149 Likes
Does Durametric allow you to read the value the temperature sensor is reporting? Is there only one sensor (unlikely..)? If you can read the value, and compare it with actual engine temperature that would be a good thing. After the light came back on - is the error code the same?
Need more info..
Need more info..
4th Gear
Need more info..
Need more info..
Keep in mind that a month ago I replaced the coolant pipes, thermostat, water pump and starter. The dash gauge always showed 180 degrees F as long as I have owned the vehicle (I bought it new).
4th Gear
I checked the wiring and the gauge displays the normal operating temperature it always has 180 degrees F. But my Durametric diagnostic tool shows an actual engine temperature of 161.6. STRANGE. I have used the Durametric to reset the code several times and it always comes back. I have to assume I did something wrong during the repairs I mentioned above. I just don't know what I did wrong.
The dash gauge is a glorified idiot light. It always shows normal temperature unless some real disaster has occurred. Porsche followed BMW with the design. The reason for doing this is the engine temperature is actually varied over a rather large range in order to maximize efficiency and minimize emissions. If the gauge indicated the actual temperature people would be flocking to the dealers thinking something is wrong. As one of the BMW engineers said at a tech session I attended "Ve vill tell you vat ve vant to tell you.."
If I had to take a WAG random guess - the thermostat has failed open or a seal associated with it has failed. Was it a Porsche part? That has a 2-year warranty, but you get to do a lot of work over again in replacing it (unless a dealer did the replacement, in which case the labor is also covered.) BTW - this falls solidly under Eilenberger's Law #3: http://www.eilenberger.net/laws.htm - Law#3 - Troubleshooting: Look where you last worked.
4th Gear
I did the work myself so looks like I get to dig into the belly of the beast again. Thanks for your help. I might just take it to the dealer, no on second thought that would be like surrendering.
