OIL IN COOLANT CAYENNE S 2004
the coolant signal went on the dashboard, latter that day i checked the reservoir and saw oil in coolant, i did a little research and saw that changing the oil cooler may solved the problem. the thing is that keeps doing the mixing (oil) in the coolant. what else can be??
thanks for the reply, The dip stick it looks fine, just oil. the weird thing is that the problem came out just a day after doing a change oil, can it be the oil filter be misplaced and causing this??
This is really difficult to read. If you write a little more carefully, people may be able to understand what's going on.
For example,
Do you really mean:
(1) changing the oil cooler may have solved the problem [i.e., you changed the oil cooler, and you think it might be solved now]
(2) changing the oil cooler may solve the problem [i.e., you have not changed the oil cooler, but you think it might fix it if you try that]
(3) something else
Tough to answer a question when you don't know what is being asked.
For example,
Do you really mean:
(3) something else
For example,
Do you really mean:
(3) something else
For example,
Do you really mean:
(3) something else
Head gasket... if your coolant light came on, then coolant is probably low. Oil in the coolant probabyly also means combustion gasses in the coolant. You can do a test for that.
https://www.napaonline.com/en/p/BK_7001006
or cheaper https://www.summitracing.com/parts/l...hoC4VwQAvD_BwE
or amazon
This test will tell you if the head gasket is leaking combustion gasses into the coolant reservoir.
or amazon
