Steering fault won’t start 04ctt
Old 06-26-2023, 05:09 AM
bezance
3rd Gear
bezance's Avatar
Default 2008 CS won't start
Originally Posted by Petza914
It's the microchip in the steering column. Find the thread on here where someone can fix the chip for about $300 instead of replacing the whole steering column. Out of curiosity, does your Cayenne have the KESSY keyless enter and drive option?
Good day
Just saw the thread. My 2008 CS won't start. I put the key and turn, only the watch, the km and the infitainment work, nothing else.
I noticed you are asking if the car has kessy.
Mine does and it has not been working for a while.
Do you think it is related?
Old 06-26-2023, 09:20 AM
Petza914
Petza914's Avatar
Received 6,717 Likes on 4,271 Posts
Originally Posted by bezance
Good day
Center display should show a fault message if that's your issue.
Old 06-26-2023, 10:08 AM
bezance
3rd Gear
bezance's Avatar
Nothing on the center display. But when I ran a diagnostics, a couple of months ago, gave me some kessy issue and driver door issue.
Could all this be related to the car not starting? Can't here the steering column releasing when i insert the key in the ignition.
Thanks for your help
Old 06-26-2023, 10:17 AM
Petza914
Petza914's Avatar
Sounds like what you're experiencing is KESSY related. Have you tried to use your other key? Is the battery in the key fob fresh?
Old 06-26-2023, 10:34 AM
Pkcayenne
Pkcayenne's Avatar
Default Kessy
I had the same issues from my original post, I removed the Kessy sent away for repair and diagnosis and they couldn’t find anything wrong, they returned it and the car started after a reset by a durametric. Gremlins were the findings
Old 06-26-2023, 11:20 AM
bezance
3rd Gear
bezance's Avatar
Yes tried the other key, same result. Haven't changed the fob battery but both seem to be working well.
Quick Reply: Steering fault won’t start 04ctt
