Warning Message?
the left headlamp was covered under warranty. I recently also had the right side warning go off in the cold weather. it stayed on the duration of that trip (and the right side xenon did not work) then when I turned off the car the warning was gone and the lights worked fine. I am guessing this has to do with the xenon gas and the cold temperature? I will post the details of the work order later
After 5000 miles, I got the cornering light message as well. At first, just one, then both lights alerted. I shut down and re-started and that seemed to re-set things. I also experienced a nav error for the for the first time (I had considered the system bullet proof). The navigation stopped working in mid-trip...later whenit came up, it shoed me in the middle of a previous trip completely out of the area. Anyhow, I will have these ghosts in the machine checked when I go in for service.
