Can speedo be calibrated for tire size?
I though I saw a post somewhere which explained that you can calibrate the speedo for almost any tire size you want.
Does anyone know if this is true, and how this works?
Thanks!
Thanks!
So far, the only info I have been able to gather is that the speedo can indeed be calibrated, but you can only select from Porsche's original and optional choices. You cannot just dial in ANY size tire.
Not confirmed, of course.
There is no need to recalibrate with Porsche recommended tire sizes. They are all about 29" in diameter, regardless of wheel size. The selection of tire size in the center display does not change the speedo.
It changes (in very small increments) PASM settings, the ride height control parameters, brake controller (the system that allows a properly equipped Cayenne to "crawl" downhill), among others. The reason is that a change in wheel means more or less compliance (tire flex) in a given range of wheel travel. A very small change in rolling diameter will have only a very minor impact on the speed/odo readings.
J
J
The original reason for asking was that some of us use (or are considering using) tires which are of non-standard size, such as 30-in diameter, and we wondered if we could accommodate the new size via this adjustment.
Thanks!
Thanks!
