ATF low alert warning
Does the Cayenne (2006 S in my case) give out a warning when the Auto Transmission Fluid gets low?
I would hope so, as could potentially wreck your gear box, but I couldn't see mention of it in the manual
There's no warning light. But if the ATF gets low enough it will be slow to shift and may cause certain gears to freewheel, and then grab, which is pretty disconcerting.
