Cayenne turbo 2005 boost?
Hello, im new to porsche and so on and got my hands on a 2005 cayenne turbo 4.5l with 500hp
. Not sure of all the teknical terms and etc for this model. But what i am wondering is if anyone knows what the stock boost is?
Because now i've never seen it going over 4-5 bar. I have the big breakes and so on.
Would like to know more about this awesom and fun car!
Thanks!
/ ulf from sweden
Thanks!
/ ulf from sweden
Seems like it is tough to get answers to this question. I asked what people were seeing on the 4.8 turbos and never did get an answer.
I think the stock 450 hp 4.5 turbo should show 0.7-0.8 bar on the gauge at max boost. On my 500 hp 4.8 turbo the gauge goes clear past the last markings at 0.8 bar pegging the gauge at its maximum.
Could be that you have faulty diverter valves that are not allowing full boost. Could be boost leaks in the various turbo plumbing connections. Sounds too low for sure at .3-.4 bar.
Thanks for the answer!
Well figured aswell that something is wrong..
Is there anyplace where i can find a "map" for the enginbay ( dont know the words haha ) or something like that.
Or can it have to do with that my "service now" message that i've not resetted that makes it go a bit to "safe mode"?
Thanks!
Thanks!
Received 1,150 Likes
Thanks!
Thanks!
Volunteers? You can PM me for an email address you can send it to - and I'll give it a shot..
The other option is looking at dealers on-line parts catalogs. You often can figure out how things go together by looking at the exploded parts listing views.
And exactly what does the message you're seeing say? Your description could be something like an oil-change message, or it could mean something is actually wrong. Are there any dash warning lights on?
The message is just to do the service, oil etc and that is already done but never got to reset the message.
Perhaps i can take som photos of the engin when im going to have a look.
Seems like i have to at this point
It may not be the N75 valve as there are many vacuum hoses that connect between the many boost related control systems.
Remove the beauty cover at the front of the engine to start. Trace all of the vacuum hoses that connect in that area (near the throttle body inlet). Then move to the rear of the engine at the top center of the engine. In that area you'll find many more vacuum lines that connect to the rear of the intake manifold.
If I had to guess you'll find a bad vacuum line somewhere in one of these two areas, or in between.
